주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
No wifi/ bluetooth upon reassemble. Gps is off on maps
Hi, I recently replaced the screen on my iphone 6. I disassembled the phone by removing the screen, attennea and did remove the logic board at one point to tinker and understand the hardware. The same phone did have some hefty damage.
Moreover, everything works fine upon reassembly with the exception that my phone does not have the ability to connect to a wifi network, bluetooth, and gps maps is off on both imaps and google maps.
What are the appropriate steps to troubleshooting the device? I want to resolve the issue? In most cases are bluetooth seperate issues vs. wifi and is the maps happening due to a latency on the ping with the server because it does locate me. However, no wifi IP would also address the issue.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Your ios version?
댓글 달기
답변 1개
선택된 답변
Most likely damage to the Logic Board Antenna flex cable. Replace that one and it should be working 100%.
iPhone 6 Logic Board Antenna Flex Cable
iPhone 6 Logic Board Antenna Flex Cable 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Stephen Sizensky 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 90
