주요 콘텐츠로 건너뛰기
new drain pump not the fix
Kenmore Elite clothes washer will not drain. The OE message appears. There are no cloggers or kinks in drain tube. I have replaced the drain pump assembly. This did not solve the problem. Before switching the pump I could drain the water out and the washer would spin to finish the cycle. What else can I do
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Theresa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 129
