주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
MacBook Pro logic board stuck?
I need to change the thermal paste of my macbook pro 15" but I have the same problem than this thread: MacBook logic board stuck?
I removed everything but the board is stuck, pivoting around a point just behind the ethernet port. I've already spent 2 days browsing the web for this issue and trying to force it (hope it's not broken already).
Pivot point is somewhere inside the small blue circle on this screenshoot:
Closer look at the stuck part:
Do you have any suggestion ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Please tell us exactly which 15" MBP you are working on. Also what problems you were having that you felt the need to replace the thermal paste.
댓글 달기
답변 1개
선택된 답변
I've had issues pulling the logic board where I needed to use a flexible spatula to break the bonding between the upper case and the speaker as some glue around the microphone adheres.
Heres a view from the other side:
The surface between the speaker and mic often has some glue.
Here's the full IFIXIT guide which you should follow: MacBook Pro 15" Unibody Mid 2010 Logic Board Replacement
But before you go down this path why do you need to remove the logic board. We might have a better answer if we knew the full story.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks it worked. I'm glad my thermal paste came with a spatula.
Apple...
댓글 달기
귀하의 답변을 추가하세요
Florian Noirbent 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 841
