주요 콘텐츠로 건너뛰기
Repair information for the Gaggia Classic Espresso Machine.
19 질문 전체 보기
Steamer no longer works
Following what sounded like a burst of water falling on a hot surface inside the machine, the steamer worked briefly then gave up entirely: no water, no steam, no sound. The coffee portion of the program still works fine. Does this sound like a failed part that can easily be replaced?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If you not descale the unit frequently, a thick layer of scale is created on the walls of the boiler.
Let’s say you never did descale the unit for like 2 years, and suddently decide to descale it, the thick scale build will unstuck from the walls forming big chips of scale on the buttom of the boiler, when you opening the steam knob, some chips may get stuck into the pipe/valve, reducing the pressure.
You should open dismantle the compleet valve and maybe keep it on a descale solution for some time to resolve the p problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
DCA 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 93
