주요 콘텐츠로 건너뛰기
The BlackBerry Classic (also known as the BlackBerry Q20) was released in 2014. Model numbers: SQC100-2, SQC100-3, SQC100-5.
24 질문 전체 보기
Call and sms not working
Blackberry Classic
Not able to phone or sms. However it works fine for mails and whatsapp in wifi mode
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
I would first try your SIM card in a known working phone. I would also try a known working SIM in your blackberry.
If you can get SMS and signal on the other phone, then something is wrong with the blackberry.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Tried both. SIM card is ok. Seems something is wrong in the phone
Ok, try downloading the blackberry desktop software to reload the OS. You should use this to backup the phone first. If this still doesn't work, then there is some hardware failure.
댓글 달기
A blackberry phone? Maybe you can try to shut it down and then turn it on mins later.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Tried. Still not working
댓글 달기
Mobile marketing has many proven results it helps in improving reputation which drives more traffic to the business it is the best marketing strategy I have seen which drives more traffic to the business.
Regards,
kevin - Bulk sms
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sivakumar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 382
