주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
screen cracked but digitzer is fine
hey my iphone 7plus screen is cracked but the touch is working can i just buy the frame(http://www.ebay.com.au/itm/Outer-Front-G...) and replace it like that or do i need to need to buy something else help please
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
So the short answer is no. Not practically.
Let me put it this way:
The process to figure out this and fix it using the part you showed us is so complicated and delicate that if you pull it off I will offer you a job for life, as well as close to 2000 repair shop owners in my network.
The analogy:
It is like buying a tooth filling for $5 and asking if you could fix your friend's decaying tooth. It is not just about the $5 part, it is about the theory you study at med school, training you go through to obtain the skill, and the $$$ machines you use to prep the tooth.
Then comes the important stuff: the ability to stand behind your work and know it is going for to last AND not got infected. This is what pro repair is about. And that repair is meant for pros, not for DYI as a first time on an expensive device. Just my opinion though,.
Oh and a final thought: most of us in smartphone repair started like that.. foolishly, out of our garage or dining room. So theoretically it can be done. Practically it is not worth the risk, time and cost unless you want to take up repair as a hobby or a job.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
It is possible for you to do, but very very difficult.
You going to need:
1.optical grade adhesive
2.Adhesive remover
4.A way to heat the glass so you can separate it from the lcd. You can do it with a heat gun, but that's the cheapest and hardest way of doing it.
I used something like this as my first step up from a heat gun
https://www.amazon.com/gp/aw/d/B019OA35J...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kevinp0930 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 12
전체 시간: 166
