주요 콘텐츠로 건너뛰기
13인치 디스플레이가 장착된 MacBook Pro 모델에 대한 수리 정보 및 가이드.
9745 질문 전체 보기
I'm trying to retrieve my iPhoto's that were put on my book
Hello. I recently put all of my iPhotos and other items on my macbook pro onto my book. I am now trying to put them on a new macbook pro however when I open up the app on the computer I cannot find any of my photos from my iPhoto app
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 5개
What do you mean onto your "book"? Do you mean another MacBook?
My Book is the name of the storage unit -- I put everything on my one macbook onto "My Book" and am trying to open up my files on a new macbook and cannot find my iPhotos
It says this when I try to open it --- None of these files can be imported into your Photos library.
Is there any reason why you are trying to open in iPhoto and not the new Photos app?
댓글 달기
답변 2개
가장 유용한 답변
You don't want to use iPhotos to import. Instead, you should use the new Photos app.
Press and hold the alt/option key when opening the Photos app, and it should let you choose a location to import from. Select the old iPhotos library from the drive. Photos will then create an updated copy of the library that will also be shared with iPhoto to save space.
해당 답변은 도움이 되었습니까?
점수 2
댓글 7개:
Hello. Just wondering which photo's app you are referring to??
Thanks!
It's the new one from Apple called Photos. Should come preinstalled on all of their devices now.
Yes that's what I've been trying to do but every time I press it it says "nothing to import. None of these files can be imported to your photos library"
I would recommend trying to use PowerPhotos https://www.fatcatsoftware.com/powerphot...
When I open the folder with my pictures from "my book" it doesn't allow me to open with power photos -- oh man
댓글 2개 더보기
댓글 달기
I would download and install a utility like
OmniDiskSweeper
that will sweep through the hard drive and show you the results in a
window to see where larger folders and files are.
The iPhoto library should be large.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
unfortunately that did not work either ....
Try Yodot to recover the pictures. You can download it here: https://f106c2fdc37239d65fa2-3e4b8066b30...
댓글 달기
귀하의 답변을 추가하세요
blueeyedb712 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 558
