Housing for Nikon D70
Hi!
I have a Nikon D70. Not using the model since the display lcd size is too small to review the images taken.
Is there any way to change the display size or will any other Nikon body fits the D70 body?
좋은 질문 입니까?
Hi!
좋은 질문 입니까?
You can set the image size and quality through the Nikon D70’s settings menus. To sum up the Image Size and Image Quality information available to the Nikon D70:
To adjust the settings, you have the following choices:
For more information please check Nikon D70 Manual.
해당 답변은 도움이 되었습니까?
The LCD on the back cannot be replaced with a different or larger one, and it is not possible to move the system into a different body shell that has a larger screen, as the circuit board/system is not designed for a larger screen.
The D80 I know didn’t have the ability to output to an external screen live, so doubt the D70 had it, as that would be the only other option if you need the screen larger.
A new body would be better, as there is other improvements to the other parts of the body other than the screen.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 88
