주요 콘텐츠로 건너뛰기
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
My 2005 c-van all of a sudden has a dead battery
! i jumped it, let it run for about 1/2 . it started fine 3 times ! got up the next morning to go to work and a dead battery !
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
pumabuddy clarify what a c-van is. I assume you mean caravan but you know what assuming does....
댓글 달기
답변 1개
가장 유용한 답변
If it has the original battery, you might want to consider a new one. After 12 years it doesn't owe you anything. You can have it tested, usually for free, at many parts stores. They will put a load on it and see if it has the current capacity. You should also put a voltmeter on it and see if you get 12.8 volts or so when the car is running. If not, your alternator needs work.
If you have a newer battery and the alternator is putting out, you probably have something loading it down. Disconnect the terminal and put an ammeter in the line, and see what it is (with the engine off).
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
pumabuddy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 121
