주요 콘텐츠로 건너뛰기
2011년 7월 21일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Thunderbolt. 이 기기는 Mac mini Server 구성을 실행하는데도 사용됩니다.
Putting hard drives to sleep when idle?
Is it recommended to put hard drives to sleep when idle?
My setting is set at never. Just wondering if it saves wear and tear.
Just replaced failed hard drive.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Yes, putting the drive to sleep when idle will be less wear on a traditional drive. But! It will take a bit of time for the system to wake up which might be a bother.
You might want to look at upgrading to a SSD. Then you don't put the drive to sleep at all as it doesn't have any moving parts! And its a lot quicker waking up.
My home Mac mini is in desperate need of upgrading as well. I'm planning on swapping out the two 2 TB platter drives I currently have to a single Samsung 850 EVO 4 TB SSD drive. It should lower the power requirement and heat.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks for the quick response.
댓글 달기
답변을 추가하세요
b biggs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 125
