주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
Unit does not power up
Description:
The light on the front of the Xbox no longer lights up and the unit does not power up nor does it attempt to. It is completely dead.
The power brick has an orange light so I don't believe it is bad, just in the power save mode. I followed the steps to reset the power to no avail.
Question:
Curious to know other's thoughts on the possible issue(s). Unit worked fine one day and then the next it just didn't power up
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개:
have you tried inserting a disc into the machine, your machine may spring to life, this will indicate either a faulty front plate or RF PCB.
Yes. No change.
댓글 달기
답변 1개
It seems that the, unit is not receiving any power out of curiosity have you tried pugging in another outlet?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Yup, multiple outlets have been tested. Followed Microsft's guide first which goes through a few things to reset power and so forth. next item is trying to find a buddy that I can use their power cable to see if that works.
Have you tried another power cord? Try with a power bar too.
댓글 달기
귀하의 답변을 추가하세요
myersavionics 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 125
