주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
How to rest serial number
Hi I am changing a Xbox one to play no games and I'm going to remove the disk drive and put the disk drive in an Xbox 360 but to do that I know that you have to replace the chip which will mess up the programming on the Xbox 360 of if I do say so does anyone know how to replace or reset the serial numbers on the disk drive and on the board itself?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Power on your Xbox console and television.
Navigate to and select “System Settings” from the Xbox Home screen.
you may need to select “Settings,” followed by “System.”
Select “Console Settings.”
Navigate to and select “System Info.”
Write down the serial number of your Xbox console.
Alternately, you can obtain the serial number from the back of the console itself or from the inside of the oval door located on the front of your console.
Press the “B” button on your Xbox controller two times to return to the System Settings menu.
Navigate to and select “Storage” or “Memory.”
Navigate to “Hard Drive” and press the “Y” button on your Xbox controller. The Device Options menu will display on-screen.
Navigate to and select “Format.”
Select “Yes” when prompted to confirm that you want to delete all content from your Xbox.
Enter the serial number for your Xbox 360 when prompted to by your console.
Select “Done.” Your Xbox 360 will now begin to reset, and restore itself back to its original factory settings.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I need to remove the serial number
댓글 달기
귀하의 답변을 추가하세요
Walker wallace 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,713
