주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
F01 error code troubleshooting
Washer had been sounding terrible during draining. And the quit running during random intervals during a cycle. Mostly right after the wash cycle. Cleaned filter, no success. Replaced the drain pump assuming it was the issue, had that problem before. Nope. Also changed the door lock switch thinking it was the safety mechanism preventing a spin cycle. Nope. Finally ran the diagnostic and figured out the F01 code. Checked my ccu for bulging capacitors or burnt out solder point. It looks good to me (though I'm not s professional). Any ideas before I go dropping money on a new ccu? I read somewhere I might have a timer issue?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@dgadoci, Drew , Before dropping money on a new CCU, Unplug machine and go over all connections, unplugging connectors checking for corrosion/burn/damage/loose wires, clean if required and reconnect making sure connection secure/tight. Service manual below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Duet-Aid_also-Kenmore-HE3.pdf
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Drew 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 7
전체 시간: 1,063
