주요 콘텐츠로 건너뛰기
2010년 중반기 모델 A1278 / 2.4 or 2.66 GHz Core 2 Duo 프로세서
794 질문 전체 보기
Will replacing my liquid damaged top case fix my issue?
About two weeks ago I accidentally spilled soda on my MacBook Pro. I did what you supposed to do when that happens and turned off my MacBook and disconnected the battery and removed the logic board so I can clean my MacBook and let it dry. The logic board didn't have any water damage on it. I waited about a week later and put everything back together, but when I power on my MacBook Pro it'll stay on for about 30 minutes to an hour then it will force shut down on it's own. When that happened I went and reset the SMC and PRAM, but the issue still happens. One thing I did notice was when I have the lid down and the MacBook is in sleep mode it'll stay on until the battery runs out. I'm assuming probably an issue with the power button, but I'm not sure. I'm thinking about replacing the top case along with the keyboard. Would that be the best solution to my problem?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hello Crimm -
Replacing your top case may not solve your issue, you will want to start here:
MacBook water damage diagnostic
Once your diagnostic is completed report back with your findings. You will also want to clean the logic board using this method -
How to Correctly clean corrosion from a MacBook Pro logic board.
MacBook Pro 13" Retina Display 이미지
안내서
난이도:
어려움
4 hours
MacBook Pro 이미지
안내서
난이도:
운영
2 hours
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Please expand your profile so we can get to know you better and maybe refer some business to you or send you business ourselves. After all we are fellow Texans.
댓글 달기
귀하의 답변을 추가하세요
Crimmm 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 404
