주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Is there any risk of Static Discharge when using with this tools?
Hi.
Is there any risk of Static discharge when working with this tools:
https://eustore.ifixit.com/index.php?cl=...
Speically the screwdriver, can it give any static discharge?
The knife when removing a cable?
Is it ESD safe?
Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Is any need to discharge srewing gun during screwing to pcb?
How to make esd ground the electrical screw driver ?
댓글 달기
답변 2개
선택된 답변
The handle in the Essential Electronics Toolkit has 3 o-rings on it, there is a very faint chance they could generate/store a charge, but doubtful. The fact the handle is aluminum and there is very little non-grounded surface on the o-rings makes it very safe.
The 64 bit driver kit handle Mako Driver Kit - 64 Precision Bits or [연계 제품이 누락 또는 비활성화 됨: IF145-326] for just the handle is ESD safe as it's all metal. (EU store link: https://eustore.ifixit.com/en/Tools/Tool... )
The handle is aluminum, a conductor, and it is not static generating. If you are taking very basic ESD measures (you are grounded to your work with an anti-static wrist strap) then it is very ESD safe. If you are not taking basic ESD measures like grounding yourself to the work environment and device you are working on with a wrist strap "ESD Safe" doesn't matter, any movement you make or tool or item you touch could potentially conduct through you and the driver handle to damage a circuit.
Non-metalic handled tools are different. Some info from the ESD association:
"If you ground a conductor (the conductive metal blade of a screwdriver for example) while it is in the presence of any item carrying electrostatic field (a charged piece of plastic, or clothing) the conductor will acquire an electrostatic charge that may be sufficient to cause damage when discharged. If the handle of that hand tool is sufficiently insulative, and if it does acquire a charge, it will remain on the conductive portion of the tool until it is brought in contact with a ground path, even if the user is wearing a wrist strap. That ground path might be an ESD sensitive component. In this case damage may occur both from initial contact with the charged hand tool and again when the charged component is grounded."
https://www.esda.org/assets/Uploads/docu...
Mako Driver Kit - 64 Precision Bits 이미지
상품
$39.95
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
가장 유용한 답변
When working with electronic there is, always a risk of, any type of electrical discharge. Such as stored power as well as discharged static electricity. Always keep yourself grounded, by wearing rubber gloves (surgical gloves work too) or keeping one hand on an object with the same, electrical potential. Screwdrivers, meant for electrical work have handle made of rubber. It's completely safe but as for everything precautions have to be taken.
The risk is there but it minimal.
해당 답변은 도움이 되었습니까?
점수 6
댓글 2개:
Good answer Aaron. For the OP, if it doesn't say ESD-Safe, then it's not ESD safe.
http://kb.hakkousa.com/KnowledgebaseArti...
Reach over and ground yourself out before starting work. If in question, touch the center screw of an electrical wall plate, a water pipe, radiator or metal electrical device with a know ground plug.
댓글 달기
귀하의 답변을 추가하세요
Eddie Geddy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 22
전체 시간: 1,717
