주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
Water damaged MacBook Pro 13" early 2015 doesn't work without charger
So I got a MacBook Pro 13" that had a glass of water spilled into it. Found some corrosion on the battery circuit board (the one attached to the battery). Cleaned it up. The computer works fine except that it doesn't work without the magsafe charger. There is an orange light on the magsafe power supply and the battery percentage is stuck on 89%, and indicates charging. But as soon as I remove the magsafe charger the computer shuts down immediately. What can be faulty? The battery itself? Or the magsafe DC-in board?
Update (05/15/2017)
The logic board itself had no corrosion at all. Removed it and checked both sides, it was perfect. There was only corrosion on the battery's circuit board, the one where the battery connector is attached to.
Actually now that I am in OS X it says it isn't charging. Probably bad battery then I guess?
The battery has 89% charge and still the computer shuts down immediately when charger is removed. What would that indicate?
I tried resetting pram and smc. I also tried smc cycle, by holding power button without charger plugged in, for 10 seconds, then connecting charger and holding power button another 10 seconds. Then when I tried turning it on the fans were spinning at 100% and coconut battery didn't report a battery installed. After that I rebooted machine and reset smc again but the problem still persists with 89% charge, like in the image above.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
If you look, it says battery failed. Meaning its dead
댓글 달기
답변 1개
가장 유용한 답변
The battery is failed and needs to be replaced.
MacBook Pro 13" Retina Display Early 2015 배터리 교체
Thats the guide on how to do it.
MacBook Pro 13" Retina (Early 2015) Battery
That is the part you need.
MacBook Pro 13" Retina (Early 2015) Battery 이미지
상품
$79.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Definitely bad battery. To note also, late 2013-2014 A1502 batteries will work fine on this model, even though it uses a different model number. Just in case the 2015 batteries are way more expensive in your area op
Check your battery using coconut battery and report back with what your specs are.
http://www.coconut-flavour.com/coconutba...
Once you report back, we can determine what needs to be done from there.
Also, when you cleaned the motherboard, did you remove it and clean both sides?
댓글 달기
귀하의 답변을 추가하세요
robert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 206
