주요 콘텐츠로 건너뛰기
The Cuisinart Smart stick is used to make blending food and juices easier for people. A hand held blender gives users the ability to quickly blend together various food creations.
5 질문 전체 보기
Lubrication of Cutting Blade bearing?
My Cuisinart CSB-75 Stick Blender has performed well for 2 yrs. Lately it has slowed down & heated near the bearing. Is there a way to lubricate the cutter bearing??
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 5개
선택된 해법
jarmush, If you are talking about the bearing in the blender shaft assembly, it will be sealed/non greaseable for food safety reasons and new part is available to change. Below is a guide on how to change the blade/shaft assy., and a couple links to possible replacement part which you can also do a search for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Cuisinart Smart Stick CSB-75 Blade Replacement
https://www.cuisinart.com/parts/hand_ble...
http://www.ereplacementparts.com/cuisina...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Richard, I did a search on the bearing/blender shaft seizing up and found this page. I had already tried what you suggested (I have worked with small and large electronics for years) and it didn’t help at all. Pretty disappointing. There’s nothing wrong with the motor housing or motor itself, though if one would continue to use it with the bad bearing, it will surely chew up the plastic ring gear that the shaft mates with. Cuisinart discontinued this item, so sadly, those of us that feel fixing is better than trashing… too bad. What to do with a motor that’s just fine, and nothing to drive with it? TRASH. Just what the planet needs… :(
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
That's not a fix, that's a replacement.
Anyone know how to take apart the blade/shaft assembly?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Seems a bit like overkill. If it’s gone far enough to need help, there is probably enough clearance between the bearing surfaces/seal to gradually oozle in a bit of food-grade caster oil (applying small amounts and hand rotating/pushing pulling the blade repeatedly) to get the bearing surfaces slippery. Even the tiny bit of play I felt in mine resolved with this exercise. It remains to be seen how long this will last, but clearly the fallback position is replacement.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had the same problem with a full size Cuisinart blender. Instead of castor oil I used a very small amount of pharmacy grade mineral oil on top and bottom of the bearing and it helped loosen the cutting blades somewhat.
Bad design from a famous company.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jarmush 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 82
전체 시간: 3,863
