Quit working wont turn on
Conair bonnet hair dryer only 3 months old quit working
좋은 질문입니까?
Suzy Cory, Try another known working outlet. If no go, more then likely has a one year warranty on hair dryer and you may want to consider contacting the manufacturer for repair/replacement/refund. If not you could disassemble the hair dryer and test/check all connections, cord/plug, switch, if fused check, with a DVOM to see if faulty. Below is a guide to disassemble various models that may help. If not wanting to work on the dryer yourself perhaps have a good local small electronics shop have a look, diagnose and estimate repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
이 답변이 도움이 되었나요?
Looks like we were answering this at the same time.
mayer, yes, been a while since it had happen :-)
It is covered under warranty. First try returning it to place of purchase.
That failing, register it here, then request a warranty repair:
이 답변이 도움이 되었나요?
If it experienced a reduction of airflow, you might have tripped the safety fuse on the heating element.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 20
지난 30일: 75
전체 시간: 12,713
댓글 1개
My Conair hair dryer stopped working, should I send it back to the company
caroljwalker123 의
