주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
My iPhone 7 will not stay on
Hello,
About a month into having a brand new iPhone 7 i had dropped it an cracked the screen a little. When I'm using it the part where the screen is broken lights up differently. You can tell something is wrong. I went a few months like that and ended up dropping it again. Days went by and my phone would turn off around 40% then 60% and now it won't stay on for more then 10 seconds without being on the charger. It doesn't have the powering off spinning circle when it turns off it goes completely black. I don't know if i should replace the screen or if its something else. I don't wanna spend unnecessary money on the wrong things. please help. Is it the LCD cord detaching or is it my battery??? I'm so clueless. Also if the top left side of phone it looks like its coming up a bit.
another thing is iv only had this phone for 6 months.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
I hope you mean LCD Cord...
lol yes idk why i even put LSD I'm such a dummy sometimes
댓글 달기
답변 3개
선택된 답변
Battery needs replacing and the display is recommended to be replaced as you will need to lift up the screen to get to the battery.
I recommend getting it repaired by apple (Approx $129 USD so it's a no brainer) as the good replacement screens are quite expensive.
해당 답변은 도움이 되었습니까?
점수 3
댓글 5개:
would you know how expensive it would be if i took it to apple?
My guess would be around $349 USD.
Last I checked iPhone 7 plus repairs at Apple are $140? Gonna go there in the next couple days. I'll ask. I'm thinking the damaged display is now over drawing the current from the battery
I was basing prices off the original replacement screen price online.
It's probably cheaper from apple store.
Apple website says $129 USD that's good and cheap.
thank you i will take it in today
댓글 달기
가장 유용한 답변
It is probably the Screen Assembly. If it is flickering and not functioning properly, that is a strong indicator of LCD Malfunction. However, from the issues you describe, it could also be the battery, or even a combination of the 2.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Maybe the LCD start giving up. You should replace the LCD first, if issue dont go away then check the battery.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
sabrina 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,045
