주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Battery Replaced Problem and Device
So recently i just recently switched my old battery with a battery from my old iPhone 4S but after i switch the batteries my phone had so many issues i'll give you some list to understand my problem below;
1.Device keeps on and off.
2. Device says 100% fully chrged, but when you pull out the charging cable it will shuts down like dead, LOL.
3. Network is searching
4. Keeps on rebooting
5.Wi fi grey out.
There you have it i hope somebody could help me on how to fix this,i tried to watch some tutorials on the net but no luck for me, so i hope and pray that in this forum someone could teach me and tell what should i do and how to fix this problems and issues. Thank you and God bless
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Does your old battery have the same issues? Also are you sure all the connectors are plugged in properly?
I'm not sure if the connectors are plugged in will on the battery :) thanks for you answer
댓글 달기
답변 1개
선택된 답변
Sounds like either the battery or the battery connector got damaged.
What tool did you use to remove / pry the battery out?
Did you make sure to unplug battery before removing the battery physically?
Have you inspected the battery cable itself for any signs of tear / physical damage?
Also check the battery connector if it's damaged as well and make sure you have plugged it in fully.
1 and 2 correlate with each other, looks like the phone can't detect the battery properly.
3. That is normal as unplugging the battery resets date and time to 1/1/1980 which is fixed by either auto synchronizing date/time via Wi-Fi, iTunes or Sim Card Cellular Data.
4. Related to 1 and 2, not detecting battery properly.
5. This is bad news. That generally means the Wi-Fi chip has gone bad and at this point I would consider using the other iPhone 4S that doesn't have Wi-Fi greyed out.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you sir i will test and look again tomorrow and see if i can fix it all anyway thanks i hope you have a good day thanks
댓글 달기
귀하의 답변을 추가하세요
techyguY 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 94
