주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Can a iPhone 6 boot without front camera/proximity sensor
Hello,
I bought a used iPhone online, unfortunately, it wasn't exactly as described.
The iPhones misses the front cam Assembly and proximity sensor. Note that the touchID cable also has been ripped.
When testing using a test-screen I don't get further than the Apple logo. Could this be because of the missing parts?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Nope. Should still be able to boot without the parts plugged in.
You can turn on pretty most devices with a battery, screen, logic board and power button connected.
Sounds like either faulty battery or software needing to restore (If you do try to restore software using iTunes please do post the iTunes restore error code if it fails).
해당 답변은 도움이 되었습니까?
점수 5
댓글 7개:
Can the phone be put in recovery without homebutton?
I don't think it's possible if the phone won't fully boot into iOS.
Unless someone can confirm which pins to short for the home button extension cable connector on logic board to trigger a home button press / hold.
Even weirder thing, when trying now the iPhone gets the red screen, a google showed up that this could be due to damaged proximity flex but non is attached.
Start by trying to restore it.
I have an iP-6 coming in soon, Ill try with that one's home button
댓글 2개 더보기
댓글 달기
Can a iPhone 6 boot without front camera/proximity sensor?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Luke Geelen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 16
전체 시간: 5,435
