주요 콘텐츠로 건너뛰기
Samsung Galaxy S5 NEO (SM-G903F)는 Full HD 해상도 5.1인치 Super AMOLED 화면을 장착하고 있습니다. 전면 카메라와 후면 카메라는 각각 5 megapixels과 16 megapixels로 작동합니다. 휴대폰 내부에는 64-bit Samsung Exynos 7580 프로세서, 16GB 내장 메모리, 2GB RAM 및 2,800mAh 배터리가 장착되어 있습니다. 치수는 142 x 72.5 x 8.1mm, 무게는 145그램 입니다. 최초 S5와 비교하여 Galaxy S5 Neo는 전면 카메라, FM 라디오 및 더 빠른 LTE (Cat6)와 같은 더 나은 기능을 제공합니다.
21 질문 전체 보기
My charger cannot insert into my phone
while i was out, i noticed my phone was going to die, so i put it to charge for about 10 minutes and took it out. half an hour later, i decided it would be a good time to leave it to charge again, but the charger wouldn't go in. i then went to try multiple chargers, none of which would go in my phone. i asked a friend and he says there's something stuck in there. i don't know if that's the case because my friend says the charger i used still worked, but i still don't know what's wrong.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Either something is stuck or it's damaged. The actual connector inside the port likes to separate into two pieces after a while. Then you jam in the charge cord and damage the connector. Really common. If you take a close look into the port you can usually check and see if there is any noticeable damage.
Hopefully its not broken, as it's a rough repair to replace the chargeport. I would take it to an awesome technician unless you want to break the LCD and be stuck with a $150+ repair!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Try cleaning it search in the youtube whats the best thing to clean it .just be very careful not to damage the part inside and dont ever put your connector in force it might really break the internal .It will really cost much in solving that issue and definitely will open your device .
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Rachel Harper 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 26
전체 시간: 2,126
