주요 콘텐츠로 건너뛰기
Apple 워치 시리즈 2 는 2016년 9월 7일에 발표되었고 2016년 9월 16일에 출시되었습니다.
Help! Debris stuck in Digital Crown!
Hello iFixit! I need a bit of help here because I cleaned my Apple Watch Sport 2 With a alcohol prep pad, and some of the cloth is now stuck inside the digital crown, making it hard to turn on occasion. My nearest Apple Store is 2 hours away and I have all the tools to DIY it. What should I do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I would also like if it could be done without opening it as I like my waterproofing seals!
댓글 달기
답변 2개
선택된 해법
@reedcrosby,Reed, You may have to get yourself a cheap dollar store magnifier/glasses to aid in seeing if fibers are accessible to dislodge with a small pin/compressed air(should work). If not then you may have to partially disassemble watch to get at debri. Link below shows how to disassemble, if need be. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Apple Watch Series 2 Teardown
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
Thank you! I never thought of that...
@reedcrosby, Reed, Welcome, thanks for replying back and good luck with your Apple watch.
Thanks for the luck, I might need it!
댓글 달기
Try getting some tweezers and just slowly getting rid of all the fibers, they should eventually come out.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I would, but the issue is I cannot see them but I can feel the resistance from them.
댓글 달기
답변을 추가하세요
Reed Crosby 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 27
전체 시간: 3,359
