주요 콘텐츠로 건너뛰기
모델 M2453 또는 M6411 / 300, 366, 또는 466 MHz G3 프로세서
64 질문 전체 보기
My iBook doesen´t turn on. He make a three "bip". What´s it?
The ibook clamshell doesen´t turn on. I press the button and he makes a signal sound like a short "bip" three times.
I know that mac make sounds to inform that kind of problem is happening. But yhis i don´t know.
Thank´s!!!!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
3 beeps at startup means bad RAM or possible bad MLB. Best course of action see if you can find another stick of RAM to test in the machine that matches the specs.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Replace ram,if it continues replace motherboard
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i went a bit on the hardcore part on the onboard RAM. I have replaced at first the ram stick, that was a no go, i have replaced the on board rams X4, still a no go. i'm gonna have to say that it is the "Bios" chip that is gone. Not sure which one is the actual Bios "SMC" chip. I do have some spare boards around to fool around and try to pin point the cause of the 3 beeps.
댓글 달기
귀하의 답변을 추가하세요
Maritza 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 11
전체 시간: 1,292
