주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone flash is disabled/iPhone needs to cool down to use flash?
I have been having this same issue for over a month ago and even after surfing online for the solution and trying them(changing battery, hard reset including all the solutions here) nothing worked. Yesterday while checking up fixes on YouTube I saw a recent video on how to fix this issue and it actually worked for me. It even teaches how to fix iPhone touch pad issues. Hope it works for others too...... video link:
https://youtu.be/lQbAd8Ws5Ek
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
You were searching youtube for fixes and found your own video? rofl. nice try to get views
댓글 달기
답변 6개
가장 유용한 답변
What you did on your phone is a liitle bit dangerous for it .Removing the Lcd or the flex cables withour removing your battery may cause shortage to the board luckily on your case its not damage or what .Always remember remove the battery first before anything else .regarding to not using proper or lacking of tools in opening the phone may result of damage to the board so keep that in mind.
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
True remember. The video said to go search on how to open up your iPhone before completing the video. As a precaution. Also said she had no experience on opening phone and had less materials too
Ironically when unplugging or plugging in screen cables while a power source is connected to the phone (especially battery) can end up short circuiting the chip that controls power to both the rear camera and the front camera as the connector of the screen cables itself can accidentally touch something it should not on the logic board.
Video wasn't too elaborate anyway but it helped fix mine
댓글 달기
Back Camera and LED/Flash not working, Wifi is extremely weak. When I open the camera app, front camera works fine but when I switch to the back camera the display goes black. In the top left corner it shows the following message, "Flash is Disabled - The iPhone needs to cool down before you can use the flash."
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I had these issues too. Go check this https://youtu.be/lQbAd8Ws5Ek to fix it. I hope it works for you
Similar problem. Bought replacement camera (under £3) but when dismantling camera I noticed a loose connector, (one of the 3 you need to dis to remove screen) Refitted properly and ensured the little plate was seated correctly. Phone now works properly.
댓글 달기
Okay so this issue can happen from a loose rear camera connection to logic board.
If you do not have the metal plate that covers the screen and rear camera connectors on the board the cable for rear camera can easily become loose on unplug so check for that and reseat as needed.
Had clients come in for that before.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
loose camera flat connector
open the phone, check the connector of camera and logic board.
everything is fixed
flash and back camera is ok right now
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Guys , I have I phone 7 plus . The same problem happend to me when I drop the phone in the floor . I been trying online solutions for about one month . No use . I even go to the repair store and check the cable connection, if there was some loss . No result . I live in Ethiopia there is no Apple store .
When someone contact me to buy I cloud closed iPhone 7 Plus , I took the risk and buy it . I replace the camera with from the I cloud closed iPhone . My phone now works perfectly.
In my suggestion, am nat an expert on hardware , the cameras may be sensitive and can be damaged easily.
Replace your camera with new one . It works 100%
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Loose camera flat connector
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
hi friend iam ipohne 6 back camera flash is disabled problem can u help me
댓글 달기
귀하의 답변을 추가하세요
Toyo Akoms 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 42,294
