주요 콘텐츠로 건너뛰기
A portable wireless bluetooth speaker introduced in 2013 by Beats by Dr. Dre.
27 질문 전체 보기
Flashed Beats Pill Plus
My company was recently throwing away a Beats Pill+ that has been "flashed". They told me I could have the speaker if I wanted because it was going in the trash anyway. The flashed Pill has been reprogrammed to only work with an aux cable and when it is plugged in. The Bluetooth and charging capabilities have been disabled. This was done in case someone stole it during our expo they wouldn't be able to sell it. Is there anyway for this "flashed" Pill+ to be reverted back to factory settings? Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
Nah the factory reset didn't work. I think is was programmed either from Apple or Beats to not be that easy to revert back to the factory settings.
Same problem did anyone else get any suggestions please update
댓글 달기
답변 1개
선택된 답변
So there is, however I'm wondering if the settings it was originally on was a display mode, which will likely be unuseable to anyone besides the retailer. Here, try this first, then come back to us
Use the Lightning to USB cable to plug your Beats Pill+ into a power source.
Turn the speaker on.
Hold down both the "b" button and the power button for 6 seconds.
The Fuel Gauge flashes red 6 times.
Your Beats Pill+ is restored to the settings it had when it was purchased.
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Correct my guess is that the factory settings are set up for display. So no one can steal it. It can be erased/reset but you'll likely need some code, from the supplier
Does the answer to reprogramming it involve coding or wiring?
댓글 달기
귀하의 답변을 추가하세요
Tee Dubs 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 33
전체 시간: 4,029
