주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
Battery overheating despite replacement
Battery overheats to around 68 C then device shuts down. Power saver does not work. I installed a custom ROM (Lineage OS 14.1) and that seems to work, it functions like a normal phone except I can't play games for long periods. Idle temps on custom ROM and set to battery saver sit L's around 42-45 C. I have tried replacing the old battery (Anker 3220mAp) with another anker battery but still the same problem. Could the sensor on the motherboard be dead or damaged? As when it says temps are 66C the phone does not feel hot at all. Even when removing the back cover to feel battery, it does not feel hot. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
issue still persist even with OEM battery. Going to give up on this one, sell it for parts. Thanks anyways
댓글 달기
답변 1개
가장 유용한 답변
I recommend replacing the battery with a genuine Samsung battery.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Yeah, I ordered one on amazon, arriving tonight. Will see if that works!
new battery just arrived, idle temps are 45-46 C but off power saver, on power saver it sits around 41-42C
댓글 달기
답변을 추가하세요
ameer7867 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 445
