주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
전문가 및 파워 유저를 위한 Apple의 노트북 라인입니다. 현재까지 맥북 프로 라인에는 13, 14, 15, 16, 17인치 제품이 있으며, 프리 유니바디(오리지널), 유니바디, 레티나 디스플레이, 터치 바, SOC(시스템 온 칩) 디자인으로 구분되는 주요 개선 버전이 있습니다.
MacBook Pro not charging.
The power cabel is conected to my Macbook pro and plugged in. The charge light does not come on.
My Macbook pro doesnt want to switch on.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Please help me!
Did you try taking the battery out and putting it back in?
댓글 달기
답변 3개
가장 유용한 답변
First let's see if the mag-safe is powered. Use a multimeter and test the output of the pins. The pin out is on the right of this wiki: https://en.wikipedia.org/wiki/MagSafe
이 답변이 도움이 되었나요?
점수 1
댓글 달기
It is most likely an issue with either the battery or your charger. I would first try to reset the SMC by powering down the machine, plugging in the charger, and then holding the left SHIFT + CONTROL + OPTION + POWER BUTTON for around 5-10 seconds. Let go, and the light on your charger will glow green and then become orange showing that it is charging. If this doesn't solve the issue it could be that your battery isn't accepting power or that your charger is faulty. If none of these are the case then it is the MagSafe port on your MacBook that is faulty. This is a bit challenging to replace but can be done.
MagSafe DC-In Board
[MacBook Unibody (A1342) MagSafe DC-In Board
Replace a broken or damaged MagSafe DC-in board for your Model A1342 MacBook Unibody with this part. This assembly connects the AC wall adapter power to the logic board and is compatible with all Unibody (Model A1342) 13" MacBooks. 이미지
제품
$19.99
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The problem is probably the battery. After removing the lower screws, remove the connection socket of the battery. Plug in and try turning on the computer. If not, try again with a different adapter.
MacBook Pro 15" Retina Display Mid 2014 배터리 교체
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Magriet de Bruin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 3
전체 시간: 2,818
