주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6s lcd glass refurbishing
Hi,
I'm refurbishing lcd for iPhone 5, 6 successful but with iPhone 6s I have little issue. After vacuum lamination and autoclave the screen has little lines in backlight. The lines are visible only when viewed from the side. I think that the press is small in vacuum laminator 2 bar and for autoclave 4 bar. Do you have any ideas ?
Thank you
Edit: I forgot to give a photo here
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
This is moisture from the autoclave getting into the backlight. This happens with the 6s onwards because the adhesive apple uses on the backlight isn't strong enough to hold the 3d touch panel. The adhesive is spongy and you can actually wiggle the backlight side to side.
To prevent this you can autoclave for less time or put the screen in a food saver bag.
The lines will fade over time. A day or 2 they will be gone or hardly visible.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you so much for your advice. Lcd really has no lines in two days.
댓글 달기
I believe @joshwalz is one of the volunteers that knows a lot about that. I'm also pretty curious as that's something I definitely need to get into
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
check the photos... the lines you can see only from the side when you look directly at the display you can see nothing
@pccheese I was trying to tag iRobot Killer...
@pccheese that's practically what I said
댓글 달기
귀하의 답변을 추가하세요
highbinder 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 185
