주요 콘텐츠로 건너뛰기
1.86GHz 또는 2.13GHz 프로세서, 128GB 또는 256GB 플래시 저장공간
147 질문 전체 보기
What is the problem with pentalobes?
First of all, if this isn't an appropriate question, because it's not specifically a problem I'm having, feel free to delete this. It applies to a MacBook Air that I want to open up.
I'm a little confused about why pentalobe screws are so strongly disliked by iFixit. Aside from them being proprietary and therefore more expensive and harder to acquire, what else is wrong with them? I think I've heard things said about them stripping easier, but I haven't found much detailed information about that. Is that something that I should worry about with pentalobes? With screws such as phillips and twi-wings, I have repeatedly removed them and put them back onto computers several times. Should I avoid screwing and unscrewing pentalobe screws like this multiple times in devices?
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Pentalobe & Allen (Hex) head screws face the same problem when the screw is a soft metal (stainless steel). The heads side wall can flex if you over stress it which then makes it harder to remove as it jams.
Phillips (cross point) screws depend on more of a downward pressure so you do need to be careful you don't apply to much downward pressure.
The lobe points can sheer on either as the Pentalobe & Allen have less meat so they tend to go before the phillips.
Straight slot screw's tend to sheer at the base of the slot as the heads wall tangs tend to be weak. Which is why many people don't like them.
The only winning point for Allen, Pentalobe or Phillips is if you need to drill out the screw the hole is centered so the drill won't skate.
I think the real issue for any tight screw:
  • Use the correct bit and make sure the bit is not worn.
  • Don't over stress the screw, consider a screw thread lock might have been used so you need to soften it before attempting to remove.
As to why companies use Pentalobe screws over Allen is mostly an issue of size. One less lobe makes a better screw when you get small.
In either case the self feeding drivers used in the manufacturing floor handle the Pentalobe or Allen screw better than the Phillip screws. As Pentalobe is a newer design its still under patent control, whereas Phillips is no longer covered. So Phillip screws are more ready available & cheaper.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Ezra 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 126
