주요 콘텐츠로 건너뛰기
This is a touch-screen controller associated with the Wii U video game console. It was released on November 18th, 2012, and available in black or white. Model number: WUP-010(USA)
83 질문 전체 보기
region lock location on the motherboard
Hello ifixit community,
here is my problem;
I have a working motherboard with the wrong region and another one with a broken DRC-WUP graphic chip with the right region. I just want to solder the chip where the region lock is located to the working motherboard.
can someone tell me, where the region lock is located on the wii u gamepad motherboard?
Thanks for helping,
rgds Thomas
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
I can’t confirm that.. I bought USA region mother board and took that chip from old board. Still wrong region gamepad. But.. I can’t be 100% sure that broken motherboard was EU region like my test console.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I found it out mysef. You just have to replace the U10 Micron 25Q256A 256 Mb Serial Flash with your original. Then you can use a motherboard with different region
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This is not a permanent fix and the gamepad will only work with the Wii U console that the old Gamepad was paired with. This might be fine in the short term, but if anything forces you to re-pair the gamepad you will be out of luck. On that note, if you try and pair the gamepad to another Wii U, it will fail with error code "165-9901"
"The update cannot be completed using a Wii U GamePad designed for a different region."
댓글 달기
Hi! You're gamepad is working??
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hannah Thomas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 28
30일 전: 59
전체 시간: 2,468
