주요 콘텐츠로 건너뛰기
Galaxy S7 Edge는 Samsung의 2016년 주력 휴대폰 Galaxy S7의 곡선형-스크린 버전입니다. 2016년 2월에 발표되었으며 3월 11일에 출시되었습니다. 모델 SM-G935.
369 질문 전체 보기
When my younger brother was using my Samsung galaxy s7 edge, he chang
When my younger brother was using my Samsung galaxy s7 edge, he changed the language of my phone to Chinese , he changed my pattern and also did something to my phone, were that when I want to power off my phone, they are asking for the pattern. What can I to to gain access back to my phone.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Once the phone has a screen lock enabled and you or the other person does not know / remember the code to unlock it, the easiest way is to perform a Wipe data / factory reset in the recovery mode menu.
To do this you will need to :
  1. Turn off the phone
  2. Hold Volume up + Power + Home, release power once you see the Samsung text displayed and keep holding the other keys until you get into the recovery mode menu. Initially it will display a blue screen with Android logo saying updating system software or something like that, let that go and it will eventually boot into the recovery menu.
  3. Use volume up and down keys to navigate the menu
  4. Once you have selected Wipe Data / Factory reset press power button to confirm doing it.
  5. Note that this will wipe all data on the phone, if you need to backup data then sorry but you are out of luck in this case.
  6. After wipe data / factory reset is done reboot the phone and wait for the phone to fully boot up which may take some time.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Maybe theres a factory reset for samsung galaxy, but it will wipe all your data. Or go to the samsung services center, they will open the pattern for you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Swipe down the top of screen to pull down the Notification Shade.
Tap the Settings button in the top right corner of your screen.
Swipe up to scroll down
Tap language and input
Tap language
tap language of your choice
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Arvin Subramaniam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 100
