주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model A1661, A1784, 또는 A1785. 32, 128 또는 256 GB 환경 설정 / 로즈 골드, 금색, 은색, 검정색, 칠흑색 및 (Product)빨간색으로 제공됩니다.
1364 질문 전체 보기
Both cameras and flashlight not working after screen replacement
After a screen replacement both cameras and flash light aren't working. The earpiece wasn't at first either, then I replaced the front camera ribbon cable and proximity sensor. Earpiece started to work but the cameras are out showing a black screen. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개:
Have you perhaps tried plugging on the old screen and see if both cameras remain dysfunctional ?
Did you make sure to unplug battery (including cutting all other power sources to phone before unplugging any other cables) when doing the repair?
I made sure to unplug the battery before undoing any other cables. I will try to plug in the old screen thanks.
댓글 달기
답변 2개
Maybe the connections are not fully connected.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I've snapped on end in then the other to make sure it works. Additionally the earpiece works and that part is connected to the same ribbon cable.
댓글 달기
Were the cameras working before the screen replacement? If the LCD was broken and you weren't able to check them, its possible the cameras were damaged on the motherboard at the same time the screen was broken.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kayla Ninh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 553
