주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
My iPhone turns of when restoring, help please!
Hi there, I recently dropped my phone and tried to turn it on and it did not turn on so i decided to open it up and then I reconnected the battery. I closed the phone up and it turned on but it went into a boot loop so i did some research and came to a conclusion to go into recovery mode and restore the device. It downloaded fine and when it came to installing the update the apple logo came up and then it restarted it self. it went straight back to recovery mode and gave me error '4013' on iTunes. I do not know what to do, it would be great if someone could help me out.
-Please guys do not tell me to go to the apple store, cause i really cant.
-was running IOS 10.3.2 perfectly fine.
-I have tried to use a different cable.
iPhone 6 16gb Gold
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I have tried changing the battery and the charging dock but still same error
I'm afraid the "easy" part of troubleshooting is over then, not much else left than handing over your phone to a real technician who could take care of your phone at a component level repair lab.
댓글 달기
답변 1개
선택된 답변
Error 4013 is related to communication as you might have already discovered since you already tried with a different cable. As it has been dropped, you might be in luck and it's just a problem with your charging dock.
Check that it has not been dislodged by the fall, but that's difficult as it's secured by the bracket. You can buy a lightning dock, they are cheap and you don't need to fully install it, just secure it to the connector and keep it carefully insulated from the board to avoid possible shorts and try your restore with that. If it succeeds you just have to mount it, otherwise it might be a more serious matter within the logic board.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
I've had a few cases where one was due to battery being too flat or just faulty.
Another case was the U2 Tristar Charging IC (Controls communication for battery charging and usb connection) was at fault and needed to be replaced.
An even more rare case where I had to try restoring the phone multiple times either with iTunes or 3UTools, trying different cables and USB ports behind a desktop computer to get it working.
Thanks for adding these useful and important informations. I'd have never thought about the battery in such instance. Glad to have the chance to learn something new every day :)
댓글 달기
귀하의 답변을 추가하세요
Obsidian Force 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 65
