주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides, user manuals, and service manuals for the Acer Aspire V5-573pg. This thin and lightweight 15.6-inch laptop was produced between 2013 and 2014 and was designed for everyday use, balancing performance and portability.
Noisy fan and overheating problem!
Hi all, my notebook's CPU temp when I run Edge only around 50C, and if I run more apps it starts to get higher and exceeds 60C. In general, fan sounds annoying after 40C 'most time', and it gets worse while the heat is increasing. What could be the possible problem? Does changing the fan solve the issue?
Note:
1) "I cleaned the fan and placed a thermal paste on the CPU".
2) I need the fan to be quiet because I want to record my voice on the PC. At this time I realized that I have a really noisy fan.
Thanks in advance!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Sounds like you need a good cleaning and thermal paste replacement. Luckily, there's a guide to do so, below. Make sure you take static electricity precautions, and unplug the battery. If you don't have any good thermal paste, iFixit has some.
Acer Aspire V5-571 Cooling System Replacement
[링크된 제품이 누락 또는 비활성화 됨: IF179-010]
Hope this helps!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you, I'm sure I did that we'll. Dose changing the fan help?
댓글 달기
답변을 추가하세요
Hazem 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 36
전체 시간: 2,523
