How do I repair no sound
For some some time now I have not been hearing any sound on my G60 laptop. Can anyone please assist me with repairing the sound on my laptop. Thank you.
좋은 질문 입니까?
좋은 질문 입니까?
After trying all sorts of things suggested in Microsoft and HP troubleshooting steps, I came across an HP forum in which a problem of no sound after upgrading to Windows 8 or 10 from Windows 7 was presented. The cure was as follows and it worked for me tonight:
"If your notebook has 4 GB of memory, I know you are not going to believe this, but for some crazy reason having 4 GB of memory installed on that platform causes the sound not to work.
Try this workaround for that if your notebook has 4 GB of memory...
A problem with the Conexant audio means that you may hear no sound in Windows 10 even though everything appears to be working correctly.
Microsoft suggests running msconfig.exe and heading to the Boot tab. Click the Advanced options button, check the Maximum memory box and set the value to 3072."
If you don't know how to get to msconfig.exe, there are a variety of instructions on the internet. I just typed it into the Win10 search box. Not sure if Cortana lets you do that since I disabled mine. Make sure you reboot. You should hear the Windows theme play when you logon with your password. Tada!
I hope it works for you too.
Linda
해당 답변은 도움이 되었습니까?
In fact, you don't have to drop down to 3072 ... just set it to 4095 and it fixed the problem!
Eres maravillosa!!!!! gracias Linda...!!!!
Did you recently upgrade your windows? Are all your drivers up to date? and a dumb question is your sound turned up? right click on the speaker icon and pull up the options ensure they are cranked up
해당 답변은 도움이 되었습니까?
Hi thanks for your help. I ended up repairing it myself by going in to restore setting and reinstalling a driver I may have deleted by mistake.
You don't need to lose a whole GB of RAM.
You just have to give up one tiny little megabyte.
https://h30434.www3.hp.com/t5/Notebook-A...
Works like a charm.
해당 답변은 도움이 되었습니까?
you will still only have 2.91 available can you confirm right click this- pc- properties-system-view basic info about your pc-installed memory- available ram
Not true under System it says 4GB then says usable 3072 reducing by 1MB actually reduces 1GB
해당 답변은 도움이 되었습니까?
I did this(dropped usable to 3072) and now sound works for a day or two, and then it stops. A reboot fixes it but what a pain. Is there anything else that can be done.
From what I’ve seen, this is only a problem on the Intel models. I have two different 500 series G60’s with T4300’s that both exhibit the problem. My 100 series AMD G60 can go to 4GB RAM and sound works fine without any workaround, leaving me 3.75GB of usable memory after video allocation.
해당 답변은 도움이 되었습니까?
Try doing what Jim Van Meggelen says, dropping it down to 4095 or anything less than the full 4096. That has worked for me too. Better to have more usable RAM. And quite often, Windows updates screw it up again. So write yourself a note on how to change the usable RAM again. I've had to do this several times over the years. Windows PITA! ?
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 2,341
