주요 콘텐츠로 건너뛰기
The Nikon D90 is a 12.3 MP DSLR camera capable of taking photos and video.
40 질문 전체 보기
Memory stick will not stay down
My Memory stick will not stay down. I push it in to take some pics and it pops right back up
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Thank you Very Much, I appreciate your help
Daniel Austin, thanks for replying back, good luck with your camera.
댓글 달기
답변 1개
선택된 답변
Daniel Austin, Could be a broken piece off card/dust/debri or damaged inside the card slot mis-aligned lock spring/pin. Use a magnifier and aim a flashlight down the slot and see if there is anything obvious causing the issue. Also try another card if all looks good. If it ends up that the camera needs a new SD memory card slot, it is soldered to the mother board and would be best to have it checked out at a good local camera shop and estimate repair. Links below may be of some help, 1st/2nd link are forums that talks of your issue and 3rd link is video showing what he found to be the problem. Last link is a replacement card reader. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.thephotoforum.com/threads/nik...
https://www.flickr.com/groups/867288@N20...
https://www.youtube.com/watch?v=QMwO_Y0U...
http://www.ebay.com/itm/SD-Memory-Card-S...
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Daniel Austin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 231
