주요 콘텐츠로 건너뛰기
The Xiaomi Redmi Note 2 is an Android smartphone sold by Xiaomi, a Chinese multinational electronics company and released in August 2015. The Redmi Note 2 was sold in two variants, the standard and the Prime. The Redmi Note 2 can be identified by model number 2015051.
18 질문 전체 보기
Phone shutting down randomly, unusable.
My Redmi Note 2 is randomly shutting down even when is connected to the charger. This started to happen after the battery swallen up, which was replaced with an original one.
I read online it coud be a rom problem but the is currently running the official global rom and I tryed the official chinese one but the issue persist, TWRP is not installed, fully stock rom.
So this can only be an hardware issue, any thoughts on what is causing the problem?
If I replace the motherboard will it fix the problem?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
this could be alot of issues, the thing i think of when a battery swells up makes the phone unusable is that is could leak form the battery on to the motherboard and make it unusable, so yeah you could try a new motherbord but you never know untill you tested that out..
Update (06/29/2017)
and are you using an original charger?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bruno Goncalves 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 1,030
