주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 Apple MacBook Air 중 더 작은 노트북.
149 질문 전체 보기
MacBook Air Mid-2013 Charges, Won't Turn On. Fixes?
The laptop charges (as in, the LED on the charger changes from orange to green) but absolutely refuses to turn on. Keyboard appears to work, as every time I did a SMC reset, the LED on charger flashes from orange to green. PRAM and SMC reset did nothing to help.
Any ideas? I do have another Macbook that works, if connecting them might help for some reason???
Thanks guys!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Can you give us some background here... Did you drop or bang the system? Did you get it wet or spill something into it? Did you have some problem before hand or smell something burnt?
댓글 달기
답변 1개
선택된 답변
Remove the bottom cover, disconnect everything except the dc board and fan. Plug in the charging cable (it will light up dim green), if the fan spins a different part inside the MacBook is preventing boot. Use process of elimination to find out the faulty part.
If it is still not working the issue is with the logic board. Remove the board and check it for liquid damage, cleaning it with 95%+ isopropyl. If it is still not working after the clean, it will need logic board repair which requires certain tools, parts and experience. At this point, unless you have micro soldered before, it is best to send it to a shop.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
Britt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 5
전체 시간: 1,050
