주요 콘텐츠로 건너뛰기
Released August 2013. Identified by model number Z796C
19 질문 전체 보기
Editing my contact information
Hi, I have a ZTE Majesty Pro LTE Z798BL. My service provider is Tracfone/Safelink.
I am attempting to edit my contacts. When I touch the screen, I get a message that says I have disabled required permission. What permission? And how do I re-enable it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글 4개
I also have this problem and can not find an answer.
Yes help me remove message
ZTE, never again. I can't delete numbers I don't want anymore. I hate this Chinese built garbage!
My phone doesn't allow any contact to save
댓글 달기
답변 3개
가장 유용한 답변
go into your setting and enable the permissions for your contacts..should be in application settings
해당 답변은 도움이 되었습니까?
점수 5
댓글 4개:
there are no permissions under settings, I have the same issue, there are no permissions under the apps either for this.
I had same problem on new phone and stumbled around for several days. Then happened across this and turned on all permissions in contact applications and the edit now works. Now I have to figure out which permissions I can turn off!
Phil Starr
Thank you Phil Starr, I turned on 'all permissions' in contacts an was able to edit my mom's ZTE cell. Thanks again!
How do I find the contact applications so I can all he permissions?
댓글 달기
These Instructions were given me by a Engineering Student (who will be designing Cell Phones) at Walmart in a Cell Phone Kiosk. It was for the ZTE ZFIVE G
Home, Settings, Apps -
NOT apps as I was doing.
Then scroll down to Contacts…
Permissions then…
Storage - Slide the slider thing to the right.
Hope this helps - (I mentioned to her that non of these instructions were “intuitive” - who would think of it and not mentioned in the booklet either - errr! Please when designing cell phones make it intuitive. MHO
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How to restore contacts
Update (09/01/2020)
It did not
Resore contacts
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
On cell majestic. Zte
댓글 달기
귀하의 답변을 추가하세요
Elena Vaccaro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 7,883
