주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
My controller randomly disconnects
So my Xbox one controller will start flashing then turn off then kick me offline. It does it more frequent than ever right now. I heard something about the wifi card will work and help but I wanted to see if y'all had an answer. How do I fix?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 2개
I am facing a similar problem. I will be playing a game and my controller will randomly disconnect but the light will stay on. My screen will then state “you need a controller to play this game.” After I take out the batteries and put them back in, it will work for another few minutes. If I don’t use the battery way, the controller will reconnect in about 10 seconds. As you can imagine, this is very aggravating when playing online games. Any suggestions?
댓글 달기
답변 2개
선택된 답변
Yes the WiFi card was my initial thought as i read what you explained. it would certainly be the first thing i would try. if you really wanted to put it to the test, keep your controller plugged in with a USB cable to the console. if your internet disconnects and the controller stays connected i am certain its the WiFi card. its a pretty easy thing to replace thankfully. only mission about it is opening the case
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
There us a known issue with xbox ones being in Instant On. I would suggest changing that to Energy Saving and see if it fixes the issue. Mine was doing the same thing til I found that solution. No more problems since.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Shawn Lindeborg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 4,430
