주요 콘텐츠로 건너뛰기
Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
212 질문 전체 보기
No video (black screen) upon boot, is it my logic board?
Thanks to the excellent info on this site I have tried the following things that all result in the startup chime, but no video:
  • Start from intall disk, holding down C
  • Start from install disk, holding down D (hardware test)
  • Reset PRAM w CMD+OPT+P+R
  • Change RAM to known good RAM
  • Using known good RAM test each RAM slot independently
I was also able to access the hard drive just fine after booting into firewire target disk mode (holding down T)
I will need to buy an adapter and borrow a friends monitor to test the external display. If I do so, what is the value of this test? Determining if it's the LCD itself vs. the logic board?
I no longer need this computer but I want to either fix it myself (I am capable of an easy or moderately difficult repair) or accurately describe the issue if I sell it as-is.
Thanks in advance!
Caitlin
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
If the external works then your GPU (graphic processor unit) is fine.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Caitlin Dean 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 1,966
