Jura J5 Won't dispense coffee or water , but runs
My Jura J5 does not dispense coffee or water, but runs. It collects in the tray instead. What can I do to fix it?
좋은 질문 입니까?
좋은 질문 입니까?
The drain valve needs to be rebuilt. I had the same problem with my Jura. I disassembled it and rebuilt the drain value and brew group. It is back up and running after replacing the o-rings and regreasing the parts. There’s plenty of videos on YouTube that shows you how to rebuild it. You can buy o’ring rebuild kits on eBay.
해당 답변은 도움이 되었습니까?
Where is the drain valve?
It's attached to the bottom of the brew group.
Hi there,
It sounds like the water lines are blocked with calcium. Have you descaled the machine?
해당 답변은 도움이 되었습니까?
Your drain valve is failing, allowing coffee to drain to the pan. It's a common problem. Either the seals are bad, or the steel plunger rod's plastic cap has unseated. Buy a rebuild kit for the drain valve, and consider gluing the cap on.
해당 답변은 도움이 되었습니까?
It might be the heat exchanger clogged with calcium. Locate the part and take it off. Unscrew the part and soak in descaler not clean. Reinstall.
해당 답변은 도움이 되었습니까?
** if not clean
Hey Richard. Thanks for the suggestion. Can you please tell me where the heat exchanger is located?
wish you could photo these parts so I know what is what
해당 답변은 도움이 되었습니까?
Coffee dispenser works one time. Next time just dry grounds and no coffee at all.
The pump works? I would then follow these instructions for replacing the seals in the brewing unit and drainage valve (in the bottom of the brewing unit)
24 시간 전: 3
7일 전: 17
30일 전: 71
전체 시간: 14,750
