aluminum covered chip glued to DVD below keyboard
PowerBook G4 Aluminum 15 1.5-1.67 GHz
I have a pb g4 and in tearing it down for HD replacement, I found an aluminum foil covered chip that has a cable and attaches to the MB small white connector to J3420 (MB Connector that is 1" above the upper right corner of the dvd player). looks like 3 wires in the single small cable. This is on top of the DVD player & under the keyboard. Help EMC. 2076
좋은 질문 입니까?
댓글 4개
What about it? Can you locate it here? PowerBook G4 Aluminum 15" 1.5-1.67 GHz Logic Board Replacement
mayer 의
Yes, it is the yellow item with the green cover, on top of the dvd drive. It plugs into the logic board right above it. I just wondered what it is. thanks and if you know what it is Id appreciate knowing. thanks
Mike
Mike Harris 의
that was it...& thanks. Also, Im having trouble with the dvd not being recognized. I worked once or twice & now it will not kick out the disk & it is not recognized as hardware??? whats up? thanks
Mike Harris 의
New problem, new question needed ;-)
mayer 의
