주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Powering iPhone 5s on without home or power buttons?
I have an iPhone 5s and both the home button and power buttons are broken. I use assistive touch to use those functions when needed. Today my phone died while it still had plenty of battery. Normally I can plug it in and it starts up without a problem but today when I plugged it in the screen stayed blank. I don't know what to do and any help would be appreciated! Thank you!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If your phone has had a broken power button for awhile and you let the battery drain often to the point of the phones turning off then there is a chance your battery may need replaced. Lithium ion batteries will have a shorter lifespan if a person let's the battery drain below a certain percentage often (below 20-30%), especially if it's to the point it shuts the phone off. I know you mentioned that the battery still had plenty of battery left but the software that monitors the battery percentage may be inaccurate at times especially if your battery has an issue. Since plugging the phone into the charger does not power it on eventually like it should then I would start by inspecting the charge port for damaged or missing pins or if it's dirty and needs cleaned. If the charge port and your charging cable appear to be ok then you may consider checking the battery next. You can use a volt meter on the batteries connector which plugs into the motherboard to check it's voltage if desired. Or replace the battery. You did not mention if you have tried plugging your phone into your computer to see if iTunes can recognize it. If you can get iTunes to recognize the phone then it could be a software related issue or possibly a screen issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Peter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 159
