주요 콘텐츠로 건너뛰기
스크린 크기 5.3” 스크린 해상도 1280x720 Pixels 배터리 용량 2,700 mAh 카메라 해상도13MP 프로세서 Qualcomm Snapdragon™ MSM8917 1.4GHz Quad-Core 메모리 2GB RAM 저장 용량 32GB ROM (최대 사용 가능 23.21GB) 통신사 T-Mobile 또는 MetroPCS 다른 기능 Android 7 (Nougat) 운영 체제, 5MP 전면 카메라와 제스처 샷 & 셀피 빛, 4G LTE 연결성, 모바일 핫스팟, Rear Key/리어 키 지문 센서. 모델 TP260 및 MP260
How to fix my K20 plus cracked screen?
I dropped my new LG K20 Plus and the screen shattered.
How can I get it fixed?
Where to buy a screen?
What all parts do I need to buy?
Can I do the labor myself?
Do I need special tools?
If I can't fix it myself, where can I send it and how much will it cost?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 8개
Can i fix it myself. And what all has to be replaced
Is the digitizer glued on the display side or on the glass side of the screen, also what would be more effective for this repair... Dry ice or heat gun. i considered dry ice due to the fact that it is less likely to destroy the screen than heat is
my friends cell phone screen is cracked but the cell phone still works!!!!!!!
Cracked screen for LG K20 how much does it cost
My Phone Broke because I was playing with a VR headset the holder for the phone shot out my phone. Model (LG K20 PLUS)
댓글 3개 더보기
댓글 달기
답변 3개
선택된 해법
Created this repair video just because I seen this thread. https://youtu.be/59ZarYHPPrE
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Dude you are awesome! This is the process right here folks! I watched to confirm.
댓글 달기
I also have the same problem. This is my second LG K20 Plus phone and the screens on both broke with on a month of my purchasing them. The first time it slid off my bedside nightstand and shattered when it hit the floor (a drop of about 2.5 feet) and the second I simply had the phone in my pocket with nothing else in the pocket yet the pressure from my leg was enough to crack the screen.
My honest guess is the plastic body of the phone is too thin and so the phone body flexes cracking the screen. This is simply a poorly designed phone. Avoid it.
이 답변이 도움이 되었나요?
점수 1
댓글 6개:
Replacement glass screen available here while the how to video can be found on youtube
https://m.ebay.com/itm/332318337221?_trk...
Yeah so I call BS to the "you can find the teardown video on YouTube" I have scoured the internet and can't find a single tut/video on this phone..
Ì agree. I found 1 on YouTube. But it was like he was working on a different phone. All of HIS components just came right out, they weren't affixed down like all of mine were. After he pulled off the last component he says, ok so there you go. Now just put it back together in the opposite order that you took it apart!! I was like, wtf??? What about my cracked screen?
Yeah agreed. The 1 video on YouTube is for a different model, which is why the phone was different. I actually figured out that all those holes on the back where it looks like you are to pry up the back are misleading. The entire bezel is attached to the back casing so after you take out the battery and all of the screws the bezel comes off next, not the back casing only.. Hope that helps! If I ever have to do it again I will make a video and post to YouTube.
Maybe you should read comment 2 on this page and you will see the link to the youtube video.
댓글 1개 더보기
댓글 달기
just saw this video, i'm going to try it at home as well.
https://www.youtube.com/watch?v=szo_MCab...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Coincidentally his video went up a day after mine. Lol.
댓글 달기
답변을 추가하세요
Perryinjax 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 20
전체 시간: 28,911
