주요 콘텐츠로 건너뛰기
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 질문 전체 보기
dropped now only sad face and clicking noise
80 GB: I dropped it pretty hard,It wont turn on , makes a clicking noise and eventually the sad face. It will not sync, there is also a message please wait very low battery that is not illuminated. Wondering how to diagnose? seems like hard drive but could it have a torn battery connection?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
most likely, the hard drive was damaged in the drop (the clicking is the drive trying to spin up or seek). The excessive attempts by the drive to work will run down the battery quickly, and its inability to seek will cause the other symptoms.
The way the battery is set and connected in the device makes it highly unlikely its cable (or any other) could work loose or tear.
Time for a new drive...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is true David. But maybe he might able to open the iPod and check to see if the harddrive cable is connect to the logic board and the harddrive still. But it does sound like you do need a new harddrive. What you want to do if you battery says that it is low is put it on the charger (wall charger, not pc) and let it sit for about a day. After that do as i instructed above and see if that helps. If it doesn't, you definitely will need a new hardddrive.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
thanks I was afraid of that , took it apart all connections were ok still doing the same thing. was afraid of buying expensive parts I didnt need
댓글 달기
귀하의 답변을 추가하세요
david ernster 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 11
전체 시간: 3,213
