Water keeps coming back after draining, raised the drain hose turn off
Bailed the water out but it keeps filling the bottom of th e dishwasher and leaking out on the hardwood floor. I raised the drain hose and even turned off the water, and water still came back. What gives. This could take an hour or more, but it's a pain. Some times it doesn't do it. Not sure why it's sporadic.
좋은 질문 입니까?
댓글 3개
If your dishwasher will drain when you cancel the cycle. The problem is most likely a faulty water inlet valve. If you look you will notice the water is clear and over time the level is rising, it is because the water inlet valve is not seating entirely and letting a little water trickle in. Google replacing water inlet valve, it's easy and the part is cheap.
kevin jensen 의
Sometimes, getting your dishwasher working can seem rather complicated to handle on your own. Therefore, getting new hacks in your skillset will improve the dishwasher function. So, if you want to know about some hacks to keep your dishwasher working, then keep reading to learn about them. https://unitappliances.com.au/smart-hack...
Rafal Zyzanski 의
Actually i cleaned the net on the inlet of dishwasher with water . After that when I turned it on it gave a blasting sound ! And it stop working it's not turning on.
Xyz Abc 의
