주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
Dark shadow top right corner of screen?
Hi all,
My iPhone 6S + 128gb has developed this fault since replacing the screen and home button.
I took it back to my local repair shop who did the screen replacement and they fixed it so off I go all happy and then I see screen flicker when pressing the top enter of the screen. After a few flickers the dark area returns.
I go back to the store, he fixes it again only for it to return a few hours later to a lesser extent than before.
Due to the fact that it can be free of the dark area at times I don't suspect the cathode anode or diodes
What else can this be please ?
The appearance is just like the issue on this thread
Black shadow top right corner
Update (07/11/2017)
Fix was to replace the front facing camera and mic assembly
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Ok thanks for the replies
What are the chances that a new screen will not fixit ?
댓글 달기
답변 4개
가장 유용한 답변
'''Hello
because this happens often
Is not replaced in place properly, and second he can be the screen that you remplaced is Faulty.
So the best change another repair shop or take it to qualify IT Technician shop.
Good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi All,
I did a little investigation and removed the screen and found that it was not the screen I had given to the repair shop but another.
I also found that by opening the phone and closing it again the black shadow disappeared.
Does this mean that the screen is faulty or the ribbon cables >?
I did manipulate the ribbon cable to try to recreate the fault but it didnt come back.
the bend radius in one of the cables an be described as kinked. Should there be a kink or a bend ?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The display replacement may be faulty, some good solutions may be:
1. Try to get your phone repaired at an Apple Store
2. Buy this, and do the repair yourself!
I hope this answer helped!
iPhone 6s Screen 이미지
상품
iPhone 6s Screen
$59.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Ok thanks for the replies.
What are the chances that a new screen won't fix it ?
Not sure...it could be a lot of things...it most likely would be an issue with the backlight, if not...it could be caused by a faulty connector on the logic board which wouldn't really make sense since it's only one corner. You'll just have to take the risk of it maybe not working. If it doesn't work, you may need to just replace the Logic Board: iPhone 6s Logic Board
댓글 달기
Hey
A New screen and with the correct attachment to the logique board will work 100/100 but be careful with the a cable is to fragile
Good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ronen Goodfriend 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 9,150
