주요 콘텐츠로 건너뛰기
LG K7은 2016년 2월 LG에서 출시한 스마트폰으로 Android 5.1에서 실행됩니다.
20 질문 전체 보기
How to fix the unresponsive touch screen on my lg k7?
All of sudden the touchscreen on my lg k7 phone completely stopped working and I tried to do a factor reset on it and now its stuck on the factor reset part and wont let me get past that point!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
when you do factory reset sometime it takes longer time to startup need about 5 minutes and don't interrupt the process or you can stuck in bootloop if that happen try flashing your phone.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I don't understand what you mean with flashing my phone?!? And I didn't interrupt the process of it been done but with my touchscreen not working my phone is now stuck on the restarting starting part! I'm suppose to be able to touch the next button and I'm not able to do that because of the simple fact that my touchscreen isn't working at all.
stuck on restarting when phone start it called bootloop and flashing procedure it mean reinstall os (android) into the phone, you need pc/laptop and usb cable data also software to flash the phone
Why is my touch doesn't work when i use two fingers on the screen? and there is a ghost touch happening too
댓글 달기
답변을 추가하세요
yaraandpayton2007 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,605
